Topic: Transmission Mechanic Needed  (Read 5179 times)
« on: February 07, 2015, 10:35:48 AM »
I know someone looking for a good mechanic to work on the transmission on an '07 EOS automatic.  Here's the issue:
Sensor in tranny signaling hot temp, crating a false neutral. Common for this car. I have replaced sensor and wiring harness. VW said they replace valve body to fix problem. $1200. I can replace the tranny for less. But it drives and shifts great until that sensor says hot. There are 3 in there. Only one reads hot.
Any recommendations?
Re: Transmission Mechanic Needed
« Reply #1 on: May 23, 2015, 07:38:56 AM »
I could take a look at it at the shop, there was a tsb about replacing the sensor, sound like that has already been done
