Topic: Removing a 98 Jetta 5 Speed Transmission  (Read 8709 times)
« on: February 06, 2016, 07:52:14 PM »
I've got two 98 Jettas sitting in my yard.  One is decent, but missing the transmission.  The other is pretty much trashed, but has good running gear.  I'm trying to get the transmission out of the second one and put it in the first.  They are both 2.0 ABA engines with 5 speeds.
What's the trick to getting the transmission out once it's loose?  I think the flange for the passenger side CV Joint is hanging on the flywheel when I try to pull it away from the engine.  Is there a certain way it has to twist or tilt?
« Last Edit: February 06, 2016, 07:53:57 PM by Zen »
Re: Removing a 98 Jetta 5 Speed Transmission
« Reply #1 on: February 07, 2016, 11:39:40 AM »
I remove the flange, 6mm socket I think. When your going back in use a pry bar to force the flange back in to over come the spring tension on it
« Reply #2 on: February 07, 2016, 10:49:36 PM »
What's the procedure for removing the flange?  I bought a Haynes manual, but it has been pretty useless so far.  Anyway, it looks like there is a removable cap/seal in the center of flange.  I'm assuming it has to pop out to get at whatever is holding the flange in place . . . but I can't get it to budge.
« Reply #3 on: February 08, 2016, 02:28:07 PM »
yeah forgot about that, the earlier ones had a cover. you shoule be able to hit it with a punch and get it out,  it will have to be replaced
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
« Reply #4 on: February 08, 2016, 10:18:20 PM »
I can't reccomend removing the flange. It's not required and the 020s are held in with a snap ring which is a major pain to try and handle in the car.
Here is what we do.
Support engine from above
Remove rear trans mount from transmission and subframe.
Loosen all bolts from engine including starter
Remove drivers axle from car.
Remove passenger axle from transmission flange only.
Use widow maker jack in between subframe and motor to push it toward the radiator about 2".
Remove small dust cover above passenger side axle (10mm bolt)
Now grab the transmission and push the differential up so that you can pivot the trans around the flywheel and toward the the radiator.
Now it should fall on your face.
Hope this helps.
« Reply #5 on: February 09, 2016, 08:41:48 PM »
Glad to have a voice of reason, been 20 years since I've done one
« Reply #6 on: February 10, 2016, 12:36:21 AM »
No offense... But I'm calling shenanigans! 20 years ago would be 2 years before a 98 transmission got here!
« Reply #7 on: February 10, 2016, 05:32:32 AM »
It's been at least 55 years since I've done one!
« Reply #8 on: February 10, 2016, 06:01:32 AM »
You may be correct, I'm getting old. But that model came out in 91 so it is possible not to have worked on that style transmission. I remember doing one in the garage is the early 00's
« Reply #9 on: February 10, 2016, 09:30:20 AM »
I'm with Sal on this one.  Don't pull the flange.  Just push the engine forward and rotate the back of the transmission upwards and it'll come out.  The 020s are pretty light so it's not too bad to do.
« Reply #10 on: February 10, 2016, 11:30:54 AM »
I figured that was the case, I just didn't know anything about pulling an 020 and I wanted to respond!
« Reply #11 on: February 10, 2016, 09:38:18 PM »
Hey, if you want to learn about pulling one, I've got one sitting on jack stands with everything loose . . .
« Reply #12 on: February 10, 2016, 09:49:26 PM »
Thanks for all the advice.  It looked like it should come out if I rotated it up, but there wasn't quite enough room to rotate it far enough.  Moving the engine forward makes sense.
I was sick Monday and Tuesday and I had to work late tonight and I'll have to again tomorrow night.  Hopefully, I'll get off work early enough Friday to take advantage of (according the weather report I just heard on the radio) partly sunny skies and a high near 50 Friday afternoon and finally get this thing out of the car.  It's been loose from the engine and dangling from a cherry picker for nearly a week.  ::)  Now I remember why I love air-cooled VWs!   ;D
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
« Reply #13 on: February 11, 2016, 03:37:26 AM »
Let me know if you get stuck. I can come by. If you have it loose should be able to have it out in 5-10 minutes.
Sal
« Reply #14 on: February 12, 2016, 01:07:41 AM »
Thanks Sal . . . I may have to take you up on the offer.  I hope to get off work in time to work on it tomorrow afternoon.  I'm pretty sure if I can get the engine to move forward a couple of inches I can get out.  We'll see.   :-\
