It's a time-consuming job - there's a lot of screws to take out. Going off the top of my head: Disconnect the negative battery cable, remove the driver's airbag (2 5mm allen bolts), remove the steering wheel (24? mm nut), remove the wiper/turn signals, remove the radio (go to Pep Boys and get some Ford radio removal tools, they'll work on VW radios too).
Remove the vents in the center stack and remove the screws. Close the vents first and it'll keep the screws from dropping down into the A/C system. Remove the screws for the control head but leave the control cables connected when you pull everything, less to put back together. Remove the instrument cluster, a battery-powered screwdriver is really handy when taking out all the phillips head screws, they're a really fine thread pitch and about 20 mm long.
There's a hidden 10 mm nut on the outside behind the wiper motor so you may find it easier to remove the wiper linkage and motor to get to it. There's also a couple of nuts on the A/C box behind the heat shield on the firewall but there's flaps cut into the heat shield so that you can access them.
There's really no "gotcha's", just take your time and I've found that when taking a dash out for the first time, copious notes and pictures help when getting to the "installation is the reverse of removal" phase
. Be careful when putting all the screws back in, remember the plastic is probably pretty brittle by now so don't get too crazy when putting everything back together.
Obviously, the above instructions aren't complete but it'll give you an idea of what you have to look forward to
