Topic: Travis's 74 thing  (Read 45094 times)
Re: Travis's 74 thing
« Reply #60 on: April 05, 2011, 04:20:02 PM »
I think I've figured it out!  We're just hooking the pumps up backwards.  The old pumps "pumped."  The new ones "suck!!!!"
Even without asking. ;D ;D
« Reply #61 on: April 10, 2011, 01:44:07 PM »
changed oil,  look for old fuel valve, unable to find, put gas i car,  still not getting a idle, goona clamp the line between the fuel pump and carb to eliminate one  and see if it is still leaking. installed headlight trim
« Reply #62 on: July 17, 2011, 08:29:18 PM »
messed with the thing, put some gas in it, pretty sure the fuel pump is shot again, goal, to drive to cyw
« Reply #63 on: July 17, 2011, 08:31:30 PM »
I am driving the bus to CYW....
No exceptions...
I will push you up there....  ;)
 ;D ;D
« Reply #64 on: July 18, 2011, 09:39:44 PM »
fuel pump no fitty  :( :(
« Reply #65 on: July 19, 2011, 06:42:05 AM »
Wrong pushrod/pump combo?
That should have been a generator pump....  ???
« Reply #66 on: July 19, 2011, 07:02:18 AM »
It would not fit between the manifold and the block, i even tried to take the carb loose
« Reply #67 on: July 19, 2011, 08:08:45 AM »
Never seen that one happen before...  ???
« Reply #68 on: July 19, 2011, 09:10:24 AM »
I have seen that once. It turned out that some of these styles of pump with inlet or outlet coming out the top of the pump would not go under the flange that the carb sits on due to the later style of intake carrying the 34mm carb being to fat compared to the earlier DP intake. Compare your old pump to the new one. You may have to use the shorter Alt angle pump/push rod or find a pump with the pipes coming out the side (old style).  Remember, You are up there and I'm down here so I can't see it ;D
« Reply #69 on: July 25, 2011, 09:00:38 AM »
GOT THE CORRECT FUEL PUMP AND ANOTHER REBUILT CARB ON THIS WEEKEND, fired it it up after finally getting gas to the carb, idled great, lost the throttle cable holder in the grass #$@%!
« Reply #70 on: July 25, 2011, 09:09:44 AM »
That sucks. I have lost those before. I would say rob one off the heater box til you can get another one. I have since picked them up for about a buck each at the swaps and keep a few in my toolbox just in case!
« Reply #71 on: July 27, 2011, 07:35:10 PM »
got the thing running today, thanks rick, drove it to taco bell to find oil leaking fron under the gen shroud, guess the oil cooler seals are bad :(
« Reply #72 on: July 27, 2011, 09:38:58 PM »
Yay!...
 ;D
And poop.....
Eh... you'll get it dewd.... October is coming...  8)
« Reply #73 on: July 27, 2011, 09:51:16 PM »
I have alot of extra oil! :)
« Reply #74 on: August 03, 2011, 09:17:26 PM »
got the oil cooler seals in engine back together and in the vehicle, found the little tin in my parts dept that blows the sir from the oil cooler threw the front tin insted of blowong it on cly 3, really wanted to clean the motor up, but i would also like todrive it, registration had expired sept 2010
