Topic: Today In VW Collecting History... ASBug's Growing Collection  (Read 126886 times)
« Reply #240 on: July 12, 2012, 03:56:13 PM »
Can't wait to see how you do that driver's side. Make sure to take lots of pictures. Looks pretty rough down along the inner rocker panel and vertical supports.
« Reply #241 on: July 12, 2012, 04:19:16 PM »
The inner fender has already had a custom piece of C channel fabbed and installed.  The forward 1' of the rear tire well has already been replaced.  It comes with several structuaral pieces and the only thing I should have to fab is the outter skin of the body.
I would hit you up for that roof section you cut out, but it has a structural bend in the middle of it.
I am going to use some of the machine shops to fabricate a side pannel if I cannot get what I need with the tools I have at home.
I am more worried about the wavyness of the large side panel than the base @ the floor.
I litterally think in one full saturday I could have this thing sealed up and ready for a glaze and paint.
It does seem to pull and run well.
« Reply #242 on: July 12, 2012, 04:42:20 PM »
I've said it before and I'll say it again . . . I drove it a couple of years ago . . . despite having a big hole in the drivers side of the bus, this was the best driving bus I've ever driven.  Keep in mind though, I haven't really driven that many buses.  I would have loved to have gotten it . . . but I've got too many projects that I'll never finish now, and I really don't care too much for having to find a new place to live . . .
But if you ever get the hankerin' to trade it for an autostick, we might need to talk.  I might even throw a Dasher in to sweeten the deal!   ;D
« Reply #243 on: July 12, 2012, 07:55:44 PM »
I ran good when I had it but if you came to a stop and weren't in first gear,  good luck getting it in first,  once you got used to it wasn't so bad,  I still heal toe the gas pedal o. The thing even though I fixes the idle out of habit,  I didn't see a reason to fix it when I had it,  I was like a work truck
« Reply #244 on: July 16, 2012, 08:20:52 PM »
Had an epiphany on how to fix this large hole in my bus.
Add a Door!
No- seriously.  It is easier to weld in the horseshoe for the handle than to weld across a 42" in the middle of the panel.
I'll post more plans, but it involves de-skinning the door leaving the thick edge and trimming the lower skin just below the belt line and tucking the door skin below the existing belt line and weld below the beltline and grind down the radius.
More to come...
Used door = $25....
Not having a weld in the middle of a panel = Priceless.
« Reply #245 on: July 17, 2012, 12:51:07 AM »
Add a Door!
More to come...
Used door = $25....
The pull of the triangle is getting stronger!
« Reply #246 on: July 17, 2012, 08:01:58 AM »
Add a Door!
More to come...
Used door = $25....
Put a window in. Then you could look down and see how close you are to the white line in the parking space.  Yes indeed the "Triangle" is expanding. Scary isn't it ? ;D
« Reply #247 on: July 17, 2012, 08:15:28 AM »
You need to find a right hand drive bay window parts bus.  It'll have everything you need to make a double-door.   8)
Or, you can make it into a camper and make a slide-out . . .
It's a blank canvas . . . why paint a plain ol' bus back on it?
« Reply #248 on: July 17, 2012, 08:26:37 AM »
Zen, The funny thing is I seriously considered a slide out....
If I was planning on keeping this bus, then I'd do something cool like that.
BUT, since it'll be on the auction block before you can say "done". I'll just go back to a normal looking bus....
You all are just jelious you don't have my creativity!!
LOL,
« Reply #249 on: July 17, 2012, 11:20:29 AM »
LOL,
We are, but SC knows that you are jealous of his creativity!
« Reply #250 on: July 17, 2012, 12:38:43 PM »
Tru dat.
« Reply #251 on: July 17, 2012, 05:14:59 PM »
LOL,
I was wondering what you called it.  I thought trying to make something good out of a sow's ear was called  something else.  ;)
« Reply #252 on: July 17, 2012, 06:24:57 PM »
I know...
A purse!
LOL,
« Reply #253 on: July 17, 2012, 07:27:48 PM »
I know...
A purse!
LOL,
You will need a big one for your bus project.
« Reply #254 on: July 17, 2012, 11:39:26 PM »
I'm glad someone else sees the potential in this bus, heck yeah I'll need a big ole purse to haul all that mooolah to the bankie in.
 ;D
Seriously though, the more I look at this door idea, the better I think it is going to work out great! If not, I really haven't lost out, I have a great running engine for the Ghia (rebuilt), and a practically brand new set of 14" 8-PLY sidewall tires.
I think you could run these tires flat and they would not flex down.
I should be able to recoup my outlay for the bus in just parts (other than the engine).
« Last Edit: July 17, 2012, 11:43:09 PM by ASBug »
