Topic: My Rabbit  (Read 43386 times)
Re: My Rabbit
« Reply #75 on: June 02, 2013, 01:42:27 PM »
Seems like you would need to be sure the rest of the components match the new clutch
I think the pressure plate will bolt to the crankshaft. Not sure about the clutch cover. Been to long. I'm sure Russ will let us know :-\
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
Re: My Rabbit
« Reply #76 on: June 02, 2013, 08:47:15 PM »
Russ's clutch is/was a 190mm, 200mm was not available till later when the 16v came out, then it could be paired with either the larger or disk by using the smaller spline disc. An easy upgrade if you can find a supplier to do it for you is a 16v heavy duty pressure plate with your transmissions matching clutch disc spline pattern and then the 16v 200mm flywheel.
Re: My Rabbit
« Reply #77 on: June 02, 2013, 10:49:25 PM »
Well there you go, all I know is my Rabbit is back at home and driving fine. Thanks Sal and Money.
Re: My Rabbit
« Reply #78 on: June 03, 2013, 03:52:35 PM »
Sal,
i appear to have gotten an H2O VW adapter in lieu of a Subaru adapter to AC VW.
is there a difference between the early diesels and regular gas blocks for the 1.8 gas and the 1.6 diesel?
There may be a use for this adaptor in the Ghia after all....
Re: My Rabbit
« Reply #79 on: June 03, 2013, 05:11:46 PM »
Sal,
the one I picked up wasn't for a subaru?
Re: My Rabbit
« Reply #80 on: June 03, 2013, 09:16:09 PM »
OK,
After further research it is for a Subie, just a 1.8 ohv Brat engine.
So scratch my earlier inquisitiveness.
I'll go back in my box now.
Re: My Rabbit
« Reply #81 on: June 03, 2013, 09:20:56 PM »
Thread jacker!
Re: My Rabbit
« Reply #82 on: June 03, 2013, 10:16:12 PM »
Thread jacker!
Be nice Russ.  You know KC suffers from AADD . . . he probably forgot to take his meds again!   ;D
Re: My Rabbit
« Reply #83 on: June 04, 2013, 07:55:00 AM »
Oh look a purple bunny...
-What were you saying?
-KC
Re: My Rabbit
« Reply #84 on: June 04, 2013, 08:05:28 AM »
-KC
I think we need to open a clinic for the disconnected and confused. ;D ;D
Re: My Rabbit
« Reply #85 on: June 04, 2013, 11:19:47 AM »
-KC
But if "WE" open it . . . isn't that kind'a like the blind leading the blind?
Re: My Rabbit
« Reply #86 on: June 04, 2013, 12:08:14 PM »
-KC
I opened one, but I didn't really understand it and haven't really engaged it lately... ;D
Re: My Rabbit
« Reply #87 on: June 04, 2013, 12:40:07 PM »
He's color blind too! My bunny is green!
Re: My Rabbit
« Reply #88 on: June 04, 2013, 03:04:16 PM »
 ;D
Re: My Rabbit
« Reply #89 on: June 04, 2013, 03:08:54 PM »
-KC
By Jove !!!!  He figured it out
