Topic: My Rabbit  (Read 40727 times)
Re: My Rabbit
« Reply #60 on: May 22, 2013, 02:29:53 PM »
It probably was and I just wasn't aware.
Re: My Rabbit
« Reply #61 on: May 22, 2013, 05:41:32 PM »
Aw come on Russ. How could you not tell if your clutch was slipping or not ??
Re: My Rabbit
« Reply #62 on: May 23, 2013, 04:05:21 PM »
Because of the way the cable stretched slowly over time.
Re: My Rabbit
« Reply #63 on: May 23, 2013, 04:54:57 PM »
If your cable stretched would mean you would gain "free-play" at the pedal. The transmission would be harder to shift because the clutch wouldn't release enough to keep from grinding the gears.
Re: My Rabbit
« Reply #64 on: May 23, 2013, 06:06:32 PM »
Well the end result is I need a new clutch!
Re: My Rabbit
« Reply #65 on: May 23, 2013, 09:20:24 PM »
I just like to know what causes things to happen to see if I can prevent it happening again.
Re: My Rabbit
« Reply #66 on: May 23, 2013, 09:47:38 PM »
Clutches are over rated anyway!   ;D
Re: My Rabbit
« Reply #67 on: May 23, 2013, 11:15:59 PM »
I'll give a full report when we get it torn down!
Re: My Rabbit
« Reply #68 on: May 24, 2013, 11:15:50 AM »
The world awaits ;D ;D
Re: My Rabbit
« Reply #69 on: June 01, 2013, 11:52:42 AM »
Old clutch vs. new one.
Re: My Rabbit
« Reply #70 on: June 01, 2013, 01:09:53 PM »
That old disc looks like one from a GAS Rabbit. smaller Dia.  190mm??  Whats the dia. of your new one ?   I have forgotten just about everything I knew about Rabbits
« Last Edit: June 02, 2013, 11:40:13 AM by Ret.Bugtech »
Re: My Rabbit
« Reply #71 on: June 01, 2013, 10:35:41 PM »
No idea. The one I ordered was for a diesel though.
Re: My Rabbit
« Reply #72 on: June 02, 2013, 08:39:58 AM »
Are they a different size?  Hard to tell from the picture
Re: My Rabbit
« Reply #73 on: June 02, 2013, 11:45:11 AM »
I bet the new one is 200mm or 210mm and the old is a 190mm. Dang Travis, You are to tall . look closer ;D ;D ;D
Re: My Rabbit
« Reply #74 on: June 02, 2013, 11:52:58 AM »
Seems like you would need to be sure the rest of the components match the new clutch
