Topic: 71 ghia  (Read 36529 times)
Re: 71 ghia
« Reply #60 on: December 10, 2013, 01:15:02 PM »
Re: 71 ghia
« Reply #61 on: December 10, 2013, 01:28:21 PM »
Re: 71 ghia
« Reply #62 on: December 10, 2013, 02:40:11 PM »
Yes that's it
Re: 71 ghia
« Reply #63 on: December 10, 2013, 04:16:24 PM »
Just gonna remind you that the Pink one has operational parking brakes on it.
Your bud has extras as well.
Re: 71 ghia
« Reply #64 on: December 10, 2013, 07:08:42 PM »
I've gotta get over there and grab some stuff off it. It's gonna be restored but I'm not sure which pan he is going to use
Re: 71 ghia
« Reply #65 on: December 11, 2013, 08:31:47 PM »
Made the longest trip tonight,  probably a mile,  no brake lights yet,  but it is cool to drive,  I like the feel,  low to the ground
Re: 71 ghia
« Reply #66 on: December 22, 2013, 11:38:07 AM »
Spliced connectors for the brake light switch and still no brake lights ,  crap
Re: 71 ghia
« Reply #67 on: December 22, 2013, 08:21:39 PM »
Check Grounds...
My flashers are erratic, I need to check mine as well.
Re: 71 ghia
« Reply #68 on: December 22, 2013, 09:45:50 PM »
Have no turn signals yet,  gotta have brake lights though
Re: 71 ghia
« Reply #69 on: December 23, 2013, 09:10:15 PM »
Cleaned some fuses,  brake lights working
Re: 71 ghia
« Reply #70 on: December 23, 2013, 09:57:40 PM »
Still overflowing the float bowl,  not used to an electric fuel pump
Re: 71 ghia
« Reply #71 on: December 24, 2013, 06:15:21 PM »
dang nabit,went to take it for a little cruise today and the crank case is full of gas, guess when i was messing with the lights the electric fuel pump was running and overflowing the float bowl.  man this simple project has been a pain.
Re: 71 ghia
« Reply #72 on: December 24, 2013, 08:22:58 PM »
The bright side of this is you will end up with a VERY CLEAN crankcase (ask me how I know  ;) ).  Just be sure and change your oil a couple of times at closer than normal intervals to get all the crap the gas cuts loose out of the engine before it does a lot of damage.
Re: 71 ghia
« Reply #73 on: December 24, 2013, 09:12:48 PM »
Dude I have a couple of electric pumps that are the correct ones.
You either need to come by and get one before you have to buy an engine from me, or get a regulator...
Re: 71 ghia
« Reply #74 on: December 24, 2013, 09:35:50 PM »
I'm not sure if its the pumps fault or the carburetor,  the pump is wired to the coil.  Def want to get the right set up
