Topic: 71 ghia  (Read 36607 times)
Re: 71 ghia
« Reply #15 on: October 31, 2013, 01:37:49 PM »
Pop in some Doobie Bros. and get to work!
Re: 71 ghia
« Reply #16 on: October 31, 2013, 04:00:52 PM »
No joke,  got another project on the garage I need to finish,  gonna steal some parts from the pink one
Re: 71 ghia
« Reply #17 on: October 31, 2013, 04:02:08 PM »
Front beam is rusty
Offline Got Bug ?
  • Chattanooga, Tn
Re: 71 ghia
« Reply #18 on: October 31, 2013, 10:26:03 PM »
That looks like you're off to a great start!
Re: 71 ghia
« Reply #19 on: November 06, 2013, 10:30:09 PM »
Went to pull the ghia into the garage and carb was leaking,  time to rebuild,  the smell of old gas is horrible
Re: 71 ghia
« Reply #20 on: November 06, 2013, 11:33:41 PM »
Instead a nice 67 beetle ended up in the garage with radar wheels,  not mine just on loan
Re: 71 ghia
« Reply #21 on: November 08, 2013, 09:38:45 PM »
Rebuilt carb on ghia, installed still leaking,  guess I'm gonna try swapping out fuel cut off valve,  didn't replace it because I've always been told the ones in the kit aren't as good as the old ones.  Gotta get this car going before its to cold to drive,  on another note I haven't even checked to see if the heater boxes are there,  dads 67 had good heat
Re: 71 ghia
« Reply #22 on: November 10, 2013, 06:54:03 AM »
Ordered new ignition switch,  apparently the pigtail one is for a 71 ghia only,  some one cut and soldered a beetle one in there but I am going to attempt to put it back correct,  really want to be drivin this thing
Re: 71 ghia
« Reply #23 on: November 13, 2013, 07:58:53 PM »
Figured the carb issue out,  put an extra washer on the float cut out and now fuel doesn't continually pump though it and all over the engine
Re: 71 ghia
« Reply #24 on: November 15, 2013, 07:38:04 PM »
got the one year only ghia ignition switch,  now to install
Re: 71 ghia
« Reply #25 on: November 15, 2013, 08:08:29 PM »
Travis, that looks just like the one I put on the 69.  I plan on using the switch buzzer wire for a radio so I can play he radio with just the key in the ignition. It was a pain to put in... KC
Re: 71 ghia
« Reply #26 on: November 15, 2013, 09:12:52 PM »
What is in there now looks like a beetle switch with wires soldered to it
Re: 71 ghia
« Reply #27 on: November 16, 2013, 06:04:23 PM »
Got the ignition switch wired in,  crank but no start,  replace the coil after some diag, fired up,  go to drive it down to the house,  makes it almost out of the yard,  dies,  won't restart,  add a little gas,  no start,  try to put a little gas in the carb,  dump gas all over the motor,  give up for the evening
Re: 71 ghia
« Reply #28 on: November 18, 2013, 06:35:23 PM »
And the ghia makes it to the house. Guess 2 washers was the happy medium now ,  wasn't getting any fuel to the float bowl
Re: 71 ghia
« Reply #29 on: November 19, 2013, 09:29:48 AM »
State Farm decided they won't cover the ghia as a collector car,  said its not restored from the pictures I sent,  told them to take the 40 a month they want to charge me and cancel the policy,  time to shop around
