Topic: 1963 frankenstien ,im building  (Read 6364 times)
Offline thomasjm
« on: August 15, 2015, 01:16:07 PM »
id like to introduce my fellow chattanoogins to my 1963 ragtop I got it a couple months ago,and have had to rewire the whole thing from scratch ( what an adventure for a first timer on wiring  ) closest ive come to wiring anything is a bread tie on a bread sack ,so it has been interesting... next I had to pull a cheesy tilt steering wheel and column someone had installed because none of it worked,wich left me a big hole under the hood into the cab (needs welded up) still trying to find a wiper motor that fits (have purchased 2 and neither fit) I did score on an original wiper fluid bottle ,I still need to do the brakes and figure out the wiring on the master cylinder it has a 2 stage instead of a single ?? but its all a work in progress thanks for letting me share
Offline Got Bug ?
  • Chattanooga, Tn
Re: 1963 frankenstien ,im building
« Reply #1 on: August 15, 2015, 10:30:06 PM »
Cool! I have a '63 for a daily driver. When I bought it I was looking for a ragtop but couldn't find one. Mine was very original so I grabbed it. I do like a ragtop on a nice summer day!
« Reply #2 on: August 16, 2015, 12:33:24 AM »
That's sweet! Hate to hear that someone cut it up but still nice to see you correcting it anyways. Great job on the wiring; not sure I would have taken on such a task! For the brake wiring thing, the earlys used a single 2 wire switch and the lates used two three prongs. I can't exactly explain why those three prongs are so confusing, but I would try sorting it out with the two two prongs if it were up to me.
Offline thomasjm
« Reply #3 on: August 16, 2015, 02:08:56 PM »
thanks for the replies I appreciate them ,I couldn't pass up this rag top I have always wanted one I think they are happy medium between the hard top and vert ,im with you on the brake issue I think im going to change it to a sigle stage 2 prong ,im curious I went by the wiring diagram on the samba and noticed wires running to a Dimmer Relay ,I will be honest I looked all through the floor for a foot switch to clck from low to high beam ,and nothing then I was on ebay and ran across a Dimmer Relay ? do I need the dimmer relay ,thanks again for the time
« Reply #4 on: August 16, 2015, 04:58:12 PM »
Well, you only need a dimmer relay of you want to have high and low beams. I have seen the switch for relatively cheap. This one is $7 on amazon- https://www.amazon.com/gp/aw/d/B000FPXUHK/ref=aw_wl_ov_dp_3_6?colid=10SENXF8M079T&coliid=I36QC1H1ATKFLI
If you don't want one, and you just want to run low beams, don't forget to atleast run a relay to keep all of that amperage going through the stock switch.
Offline thomasjm
« Reply #5 on: August 16, 2015, 05:14:44 PM »
awesome thank you ,I will get one lol all the deer and possums in the road out here I will need the high beams  ,another question if you don't mind I read somewhere that soldering after wire crimping the the wires for the headlights gives it a much better connection is that true or does it matter,thanks again
« Reply #6 on: August 18, 2015, 03:25:07 PM »
This is like asking what oil to use! You will get a bunch of answers if you really seek the answer out. I've read about comparisons between solder vs crimping and my general conclusion was that soldering works well for small wires while crimping works great for large size wire. I have done some combo crimp-then-solder connections with good success. I think if I wanted to never have to worry about a connection, I would avoid the heavily insulated crimp connectors (red, blue, yellow) and go with the all metal crimp ons. Then add heat shrink on after crimping. This has served me well without having the ends come off like I did when I left the red, blue or yellow plastic insulation on. I avoid crimp on butt connectors like the plague and wire nuts only have a place in the house; not a car...
« Reply #7 on: August 19, 2015, 09:24:47 PM »
Back in the day when I actually worked on my vehicles, my preference was to "pre-tin" the  wire (strip it back, twist the strands tight then heat them and touch the solder to them).  NOTE:  Don't ever "cold solder" a connection (touch the solder to the iron to melt it and let it drip on cold wires/connectors).  That won't make a lasting connection.  Anyway, once the wire is pre-tinned, crimp on an un-insulated connector like Nick mentioned and wipe it down with dielectric grease and seal over it with heat shrink tubing.  It makes a great connection, the heat shrink insulates it and helps keep it from flexing in the joint and the grease keeps out the moisture in the air . . . which is what causes corrosion, and eventually, bad connections.
But in a tight, I have been know to just twist two wires together and wrap it with tape.  Or use a wire nut.  That kind'a stuff works . . . for a little while.  But you are better off if you do it right the first time.  That way you don't have to re-do it.
