Linked Events
  • September Cruise-In: September 07, 2012
Topic: September Cruise-In  (Read 18601 times)
September Cruise-In
« on: August 21, 2012, 08:38:54 AM »
Our next cruise-in will be held on Friday, September 7th. We will once again meet at the Sonic on East Brainerd Road at 7 PM. Bring a chair and hang out with us!
« Last Edit: August 29, 2012, 11:13:18 AM by Russ »
Re: September Cruise-In
« Reply #1 on: August 26, 2012, 02:03:41 PM »
A few of us have been meeting at Big River Grille (by Hamilton Place) after the cruise-in as well. Please feel free to join us for that too.
« Last Edit: September 02, 2012, 11:52:52 PM by Russ »
Offline arty
« Reply #2 on: September 05, 2012, 03:29:58 PM »
Can you guys meet in dalton one day?
« Reply #3 on: September 06, 2012, 12:30:12 AM »
During the warm months we always meet at Sonic on East Brainerd Road. However in the cold months, we tend to meet elsewhere indoors, and move around month to month. We have met at various locations around the area such as Hixson and Ft. Oglethorpe. Ft. O shouldn't be too long of a drive for you.
If you have suggestions of good places to meet in Dalton, we could also discuss it at our next meetings and see what everyone wants to do.
« Reply #4 on: September 06, 2012, 02:15:49 PM »
Does Dalton still have their big cruise-ins in the old part of town?  A bunch of us went to one a few years back and it was a blast!  Cleveland has (or had) them too.  Ft. Oglethorpe has had a few as well.  We really should try to make an organized effort to attend some of these.  Does anyone know the schedules for any of them?
« Reply #5 on: September 06, 2012, 03:42:36 PM »
I don't know about Cleveland and Dalton, but Gadsden, AL is having their big cruise-in tomorrow night and Ed is hosting his Cruising the Canyon for a Cure along the mountain top Saturday morning.
Offline arty
« Reply #6 on: September 06, 2012, 03:55:21 PM »
I have not seen any posters or ads in dalton, I know Murray county has a cruise in the 2nd sat of every month but its all muscle and  American cars. i have not seen a VW in it.
Offline arty
« Reply #7 on: September 07, 2012, 08:41:48 AM »
I need help !  I was planing on going to the cruising tonight. last night i moved my car to clean it  then I decided to move it again. OK  short story now it wont turn on. 1. battery is ok  i check the cables all are good. I think its the key switch. any advice ?  I had this problem before but after a few min.  it turns on fine now it wont
« Reply #8 on: September 07, 2012, 08:48:19 AM »
The golf or the fastback?
Offline arty
« Reply #9 on: September 07, 2012, 09:13:17 AM »
The fastback, I called American Foreign and they dont have a switch in stock.
« Reply #10 on: September 07, 2012, 09:47:39 AM »
Check to make sure that its in neutral. Then check it again. The put the parking brake on and block the tires. Lay down in front of the back left tire and you should be able to see the starter. Jump the bolt terminal to the spade connector (bolt is power from batter, spade is signal wire from switch). It should spin over. If it does, then there is a problem with the signal wire. I usually use a 14mm wrench cause its about that far apart (and I don't use the 14 much!).
That wire comes across under the backseat of a beetle and you can access an in-line connector to "jump" the signal wire off the battery. I guess its fair to ask if you are certain you are getting 12 volts to the switch? 12 volts to the coil?
Make sure its in neutral before you lay down in front of the tire and jump the starter!  :o :o
Offline arty
« Reply #11 on: September 07, 2012, 10:23:23 AM »
I will check the voltage first, the tires are blocked, for some reason i block the tires when i park it hahah  i dont know why i just do.
« Reply #12 on: September 07, 2012, 05:35:28 PM »
Hope to see you all tonight at the cruise-in! ;D
« Reply #13 on: September 07, 2012, 11:44:17 PM »
We had a huge turnout tonight! Check out the photos here: http://www.volksfolks.org/gallery/cruise-ins/september-2012/
« Reply #14 on: September 08, 2012, 11:49:18 AM »
WOW !! finally made it to a cruise-in in a while.  We had a great time and really enjoyed "Yaking" with the crew in person again and meeting some new folks. Dang!! All the Babies grew up. :o What happened ?  ;D ;D  It must have been good compost. ;D
