Topic: Suppose I had a struttt and a tire  (Read 8503 times)
Re: Suppose I had a struttt and a tire
« Reply #15 on: July 27, 2014, 02:54:18 PM »
Its purple with glitter.  I use when I got out in Drag.
« Reply #16 on: July 27, 2014, 02:58:50 PM »
It keeps coming loose and the rim clunks against the brake hub.  I have to jack up the car and reset the rim to the hub and lugs.  and tighten.  This time I had BRett,   press the brake pedal and hold the wheels while I tightend the lugs real tight with the  car on the jack.  Thee tighten again when the wheel was on the ground.  Maybe this will stay stuck
« Reply #17 on: July 27, 2014, 05:00:17 PM »
Your gonna stress the bolts and wheels out
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
« Reply #18 on: July 28, 2014, 03:44:06 PM »
Your wheel spacers are not hub or even bolt centric for that matter. That is causing a wobble which is causing your nuts to loosen. Now if you keep letting them loosen up you will wallow out your wheels, and or break a stud off the hub.
