Topic: Suppose I had a struttt and a tire  (Read 7886 times)
« on: May 30, 2014, 08:35:06 PM »
How much clearance should a strut and a tire have?  i can slide a piece of budlite card board between my new rims and tires.  2 or 3 mm>?
Re: Suppose I had a struttt and a tire
« Reply #1 on: May 30, 2014, 09:27:05 PM »
That's pretty close,  you could run them and see if the tire rubs the dirt and or paint off the strut,  if the tire looses air it may start rubbing,
« Reply #2 on: May 31, 2014, 10:40:42 AM »
That seems pretty close to me. But what's the worst that can happen?!??
« Reply #3 on: May 31, 2014, 03:25:31 PM »
That's WAAAAYYYY to close for comfort, even in "The Triangle."  So, I would probably try it and see what happens.   8)
« Reply #4 on: May 31, 2014, 08:05:00 PM »
All right   Definite maybe,    I got 4volvo tire and rims at the dump$130,   The back are cool.  Fronts rubbed.  Stuck some spacers.  Rims fit. 2 mm clearance.  Nuts are near 70 percent on the lug bolts.   Seems to roll ok.  Drove 40 mile today.   Seems triangle safe.
« Reply #5 on: May 31, 2014, 08:49:15 PM »
I'm assuming you used some fender washers
« Reply #6 on: June 01, 2014, 08:24:47 AM »
For fine adjustments, cut out shims from a beer can.  You'll need lot's of shims, so this job is going to require drinking a lot of beer first.   8)
« Reply #7 on: June 03, 2014, 06:08:45 PM »
Spacers are store bought.  They didn't fit.  Walleyed them out with a drill to get the ring over the bolts rite
« Reply #8 on: June 03, 2014, 11:32:49 PM »
Forget the beer . . . You need Tequila!
« Reply #9 on: June 04, 2014, 10:09:35 AM »
I see Dead people.
« Reply #10 on: July 22, 2014, 07:56:59 PM »
Update.  The wheels kept coming loose an throwing lugs at what ever speed lugs fly off at.   Even had a wheel fall off in front of Walmart.   I've added nail polish to the lugs and they appear to stay stuck. Victory is mine
« Reply #11 on: July 22, 2014, 11:37:46 PM »
« Reply #12 on: July 23, 2014, 06:55:54 AM »
OMG. Forget the lock tight,  I'm switching to nail polish now,  you could also use it to mark the location of the lots so you can tell when they start backing out
« Reply #13 on: July 23, 2014, 09:46:20 AM »
What color nail polish though? I hope it matched the car.
« Reply #14 on: July 23, 2014, 09:58:11 AM »
Was it your nail polish?!? I can't imagine my wife letting me take her nail polish down to the garage....
