Topic: how much trouble is changing engine on 94 toyota camry  (Read 13095 times)
Re: how much trouble is changing engine on 94 toyota camry
« Reply #15 on: August 12, 2014, 05:50:48 AM »
Thx zen.  I was gonna  work on that camry last nite when the lawn tractor acted up.  Seems the carb butter fly
Screws came loose and got sucked into cyl.  Spark plug gap got squashed.  Monday evening pulled head off,  removed battered screws,  cyl looked ok.   Tractor runs again.
On camry,  yes looks like oil pan can come off.  Stay tuned
« Reply #16 on: August 17, 2014, 09:20:55 AM »
I poured oil in the cyls it's been soaking for days.  Motor no wanna turn
« Reply #17 on: August 17, 2014, 11:19:20 AM »
Are the spark plugs out of it?  What kind of "oil" did you pour in?  Is it locked down tight, or can you rock it back and forth a little?
If you put regular motor oil in it and put the plugs back in, it won't turn over until the oil seeps past the rings, but if it's freed up, you should be able to rock it back and forth just a little.
If you put Marvel, WD-40, PB-Blaster or something along those lines, it should have leaked down past the rings after a few days.  If the plugs are out of it and it still won't turn over, you probably need an engine.
« Reply #18 on: August 17, 2014, 02:13:00 PM »
I doubt the pistons are frozen,  you probably have a bad bearing or bent rod if it was driven without oil
« Reply #19 on: August 17, 2014, 03:42:22 PM »
Yes the plugs are out.   I'm still gonna drop the pan to see the distruction 1st hand.  i cant spell distruction today
« Reply #20 on: August 17, 2014, 05:00:50 PM »
Auto correct :)
« Reply #21 on: August 23, 2014, 11:50:26 AM »
this 2 inch metal thing was sticking out of the oil pan.  what to you reckon it is?.  It burst out of the oil pan like  an Alien
« Reply #22 on: August 23, 2014, 12:17:36 PM »
Can't tell for sure, but it looks a lot like part of a rod cap.  Start looking for a replacement engine.
« Reply #23 on: August 23, 2014, 10:29:45 PM »
« Reply #24 on: August 24, 2014, 09:04:54 PM »
new plan.  electric car  camry
« Reply #25 on: August 24, 2014, 09:14:01 PM »
Why not just hook the dc motor to the transmission!?!??
« Reply #26 on: August 24, 2014, 09:16:01 PM »
this seems easier and cheaper maybe
« Reply #27 on: August 24, 2014, 09:36:32 PM »
So it won't hold oil but you are planning on still spinning the crank? How's that gonna work for more than a minute?
« Reply #28 on: August 24, 2014, 09:46:03 PM »
will the crank get oil from the oil pan?,  plus no piston heat .   maybe add a grease fitting somehow
« Reply #29 on: August 24, 2014, 09:55:59 PM »
I'm not sure your crank bearings are any good,  plus an electric motor and batteries to push that thing 45 mph will cost more than a used car in decent shape
