Topic: how much trouble is changing engine on 94 toyota camry  (Read 12136 times)
« on: December 28, 2012, 09:57:14 AM »
So the motor is dead.  Oil pours through the engine to the driveway now.  Knocking bearings.  what a mess.  The rest of the car is Ok.  Should I change the 2.2  engine? whats a used engine cost?  any advice or ridicule is appreciated.  SC
Re: how much trouble is changing engine on 94 toyota camry
« Reply #1 on: December 28, 2012, 10:04:10 AM »
Is this the SAME son who destroyed the last car?
« Reply #2 on: December 28, 2012, 10:16:52 AM »
A 4 banger at Pull-A-Part will run you about 120 bucks, plus a core charge of about another 20 if you don't have a junk engine to turn in.
« Reply #3 on: December 28, 2012, 10:30:10 AM »
Sounds like a deal,  I'll put one in it for 500,  take about 2 days
« Reply #4 on: December 28, 2012, 12:01:09 PM »
Nope this is my 2nd son.  Kids have been pretty good to cars this year.
Zen,  do I have to remove the motor at pull a part?
Travis,  I will take you up on it,  if I get a motor,  the car only has 140 k on it.  do you just change engine,  or tranny and engine together?
the worst part is I had to give  him my Super Volvo.   I have to ride in the Saab turbo convertible now.  sc
« Reply #5 on: December 28, 2012, 12:23:51 PM »
I pull them out together and then separate them,  on front wheel drive cars
« Reply #6 on: December 28, 2012, 01:32:18 PM »
You have to pull the engine yourself, but they have a big A frame they will move over the car for you.  The one I pulled a few years ago, I used a strap type come-a-long and their A frame to lift it.  Last week I saw them lift an engine and tranny out of a car with their big fork lift.  When I pulled the one I got, they carried it to the checkout on the big lift.
If you can find a good one, it's really not that hard to pull it . . . remember, you are puling it from a junk car.  You don't have to but an engine back in it . . . a lot of stuff can be take loose from the engine with bolt cutters and a hack saw.  It really speeds up the process.  Kyle and I pulled on from a Mazda 323 a few years back . . . it took 45 minutes from start to finish.  The same process took a couple of days on the car I put the engine in.
« Reply #7 on: December 28, 2012, 07:35:43 PM »
« Reply #8 on: December 28, 2012, 07:56:15 PM »
« Reply #9 on: December 28, 2012, 09:18:44 PM »
I will see if the junk yard I go to has one
« Reply #10 on: August 10, 2014, 02:45:14 PM »
ok after sitting 2 years  i finally got off the pot.  I thought it was leaking at oil pump but instead.  It is leaking around were this exhaust hanger is.  Does that mean its like a bad oil pan?
« Reply #11 on: August 11, 2014, 05:41:29 AM »
Probably not unless you put a hole in it,  may be leaking from up top down,  valve cover? Front seals,?
« Reply #12 on: August 11, 2014, 06:18:36 AM »
More info.  It it pours out when the engine is not moving.   I pour oil in top and it comes out its bottom
Also I can't seem to turn the engine.  Any tips on how to un stuck a engine?
« Reply #13 on: August 11, 2014, 08:41:10 AM »
Sounds like a hole in the oil pan then the vehicle was driven with no oil pressure and the engine locked up,  probably bearing damage,  you may as well out that used motor in there
« Reply #14 on: August 11, 2014, 11:22:15 AM »
Can you remove the oil pain without pulling the engine?  I've done this on my 96 Passat and on an 88 Mercury Tracer.  If you can pull the pan, you can inspect it for damage and maybe figure out exactly what is causing the leak.  While it's off, you can pull the rod caps and insepct the bearings . . . if the rod bearings are good and it's just locked from sitting, put it back together, pull the spark plugs and fill it with Marvel Mystery Oil . . . let it sit for a day or two and see if you can get it to turn.  If you get it turning, don't force it over in one direction . . . rock it back and forth slowly going a little further each time.  If you can get it turn a complete revolution, fill the crankcase with oil and spin it over the starter  several times . . . put the plugs back in and see what happens.  You never know.  You might get lucky.  Or you may just need to replace the engine.
