Topic: Honda Acura no spark  (Read 2905 times)
« on: October 03, 2016, 06:32:02 PM »
97 Acura won't start.  No spark.  Changed coil and igniter.  Most wires read 12 volts but do not pulse when engine turns.   I do get a pulse from a wire on a module on left side of dist.  On the picture. Right side is coil,  bottom is igniter,  left side may be a position sensor.   Any idea's. sC
Re: Honda Acura no spark
« Reply #1 on: October 03, 2016, 09:22:38 PM »
I had a one the screw fell out of the rotor. The distributers were good about going out. Need to check out u pull it on workman rd
« Reply #2 on: October 09, 2016, 04:20:59 PM »
Got a coil and igniter on workman rd.  Looks like no signal from Ecu.  Could be crank pos sensor.   Checking
« Reply #3 on: October 13, 2016, 08:23:39 AM »
Rotor Button Screw used to come loose on my '89 CRX.
dumb design...
« Reply #4 on: October 15, 2016, 08:03:24 AM »
Pulled Ecu ,opened it, nothing burnt inside.  I don't have voltage to crank pos sensor.  One related thing is we removed the wiper motor and rods to change some bushings.  Car did not run after reinstalling wiper motor and rods.
