Topic: Did someone steal my relay ? really?  (Read 9153 times)
Re: Did someone steal my relay ? really?
« Reply #15 on: December 01, 2013, 11:06:19 AM »
I squirted oil in the Cyl and the PSi stayed at 50.  I'm thinking exhaust valve.  i read that exh manifold leaks will cause valves to burn and this volvo mainfold gasket leaked big time.   I'm thinking of driving around on 3 cly's.   Is that a real bad Idea?,  Sc
« Reply #16 on: December 01, 2013, 11:13:49 AM »
I would think so,  if you removed the connector from the injector you would prevent burning up the cat I would think you could get head gasket bolts,  and valve or valves for under 100 bucks all you need is a torque wrench to put the head back on,  just make sure you follow the pattern and specs,  I can replace valves,  I have a spring compressor
« Reply #17 on: December 01, 2013, 04:23:35 PM »
Thx Travis.  Its been a heck of a holiday.  Volvo ,  changeing a saab 900 clutch slave ( which has been a total PIA,  then the Acura brake lights quit working
I went around the block in my Volvo 3 Cyl.  Not much pep but it got up a hill and went 45 mph.  I'm torn between driving it this way till it dies,  or parking it and fixing the valve.
With no gas in the 4th,  I can't under stand why it runs worse when i plug the spark plug wire up.
« Reply #18 on: December 01, 2013, 06:23:52 PM »
Possibly because its leaking into the in take?  Not really sure
« Reply #19 on: December 21, 2013, 02:27:01 AM »
Victory.. Sort of...   I had an old Bosch
 distributor cap laying around. and traded it with the new one I installed a month ago.   For some reason it ran a little better and the spark jumping between 3 and 4 isolated Better.   Now when I jerked a plug wire off I could tell which cyl was working or not. Found a bad plug, stuck in an old worn plug in its place.  Runs like a 20 year old worn out volvo should.  Thanks for you help,  I need to work on that low compression in 4 now.  Sc
« Reply #20 on: December 21, 2013, 06:56:54 AM »
Cool,
