I Smell Bacon: Take a roadtrip in 2 converted VWs that uses cooking grease
Greasecar Vegetable Oil Conversion SystemThe Greasecar Vegetable Oil Conversion System is an auxiliary fuel modification system that allows diesel vehicles to run on vegetable oil in any climate.
Your Greasecar kit comes with everything you need to convert your diesel vehicle to run on straight vegetable oil. Including had crafted aluminum heated fuel cell, Quick-flush switching and 10 micron filter.
By using waste vegetable oils as fuel, Greasecar customers reduce toxic emissions, recycle an over-abundant waste product, and dramatically reduce fuel costs.
Greasecar is the premier vegetable fuel system, a product of years of development and hundreds of thousands of test miles. The Greasecar system is the only system available with high quality tig welded aluminum tanks in three sizes for optimum fit. The Greasecar system is also the only product of its kind to offer quick flushing(in under 1 minute) and a unique fuel filter recirculation system for quick and efficient fuel heating. Don't settle for imitations when you can get the best.
Key:
* 1. Six Port Fuel Valve
* 2. Wire Harness
* 3. Three Port Fuel Valve
* 4. Fuse and Harness
* 5. Flush Switch
* 6. Dash Mount Fuel Level Gauge
* 7. Tank Selector Switch
* 8. Fuse and Harness
* 9. Heater Hose
* 10. Fuel Line
* 11. Fuel Hose
* 12. Small Hose Clamps
* 13. Small T-fittings
* 14. Large T-fittings
* 15. Large Hose Clamps
Click Here to check out the Westy
Click Here to check out the Jetta
Click Here to goto their Web Site
