Dead fuel pump... or at least full of crap, carb acting up... all a result of junk starting to come out of the tank that needs to be cleaned and lined....
Plus, I am needing some tires, another metal line on the brakes, blah blah blah...
I had another issue the other day when i was draining the oil again, and noticed a lot of solid black particles coming out with the oil. Looked in the drain hole, saw something blocking the drain hole... stuck a finger in there, and right into a 1/2" of chunky goop. Crap. Again. Decided to suck it up and change gear for the 234th time. Taking the engine out to disassemble and clean it properly. All of the sludge i saw in the oil coming out meant that the gunk was circulating in the system... that gets into the pickup, clogging it and or going through the bearings.... This way will be much more preventative versus reactive. Also, i will go ahead and take the car home on a roll-back, and after i finish the customer car in the garage, it's on to the body work on this old girl.
Not what my heart wanted, but it is what my peace of mind (and, in the long run, my wallet) needed....
