Topic: Tiny bubbles, In the coolant, make me sad.  (Read 3133 times)
« on: January 11, 2008, 07:03:18 AM »
Suppose you replace a head gasket and the engine  is putting air bubbles in the coolant.  None in the Oil .  yet..
 Is retorgueing the head bolts got any chance of fixing that?
 or should I run Block seal in the coolant.
Whats your vote?   SC
Tiny bubbles in the wine,
Make me happy, make me feel fine,
Tiny bubbles make me warm all over
With a feeling that I'm gonna Love you 'til the end of time.
« Reply #1 on: January 11, 2008, 08:08:03 AM »
What in the world are you working on  ?    John Deere, Yugo ? 8)
« Reply #2 on: January 11, 2008, 07:05:43 PM »
Its a toyota Van, 85 vintage.
Gehackt
« Reply #3 on: January 11, 2008, 11:12:15 PM »
Same thing! Toyota van/John Deere/ Yugo.
So you think the compression is leaking into a coolant passage causing these Bubbles?
After the system heats up and pressurizes, does the exhaust put out white sweet smeelin' smoke? The radiator fluid should leak back into the cylinder and burn the antifreeze.
Check oil for milky color.
Maybe there is just an airpocket in the system that just needs to work itself out!
It wouldn't hurt to retorque the head bolts either.
Drive it till there's a real problem!
Don't use block seal.
« Reply #4 on: January 13, 2008, 11:06:10 AM »
S.C.   You would need some help with this . You could do a "leak down" test. This is a test where you check one cly. at a time under pressue from a in- house compressor.(engine not running of course)
   This would show you a couple of things, worn rings, leaky valves or in your case a leaky head gasket. Air leaking from the combustion chamber back into the cooling from a bad head gasket would try to pressurize the system.  Bubbles, gurgling sounds etc.
    I don't know about Toyotas, but Hondas do not like anti-freez running through places where its not suppose to for any lenght of time.  Combustion gases , anti-freez and Aluminum makes for bad bed fellows.  ACID. I looked at a Accord engine one time after about 3000 miles of a leaking head gasket.  The head, a few pistons were eaten up. The block wasn't anything to brag about. Pitted cly. bores.
    We use this test on early VW Diesels to run down leaks. worked for us.
    Better yet. Take the "critter" to a desent Toyota Dude and say FIX. :lol:
« Reply #5 on: January 13, 2008, 01:22:24 PM »
Thx for the support Bugtech.  I spent about $150 to shave the head and the gaskets,  but it is sending out exhaust  steam and spurtin fluid when the cap is off.     I think I am going to loosen the head and retorque for some giggles,  I can't pay Toyota guys to fix this.  SC
« Reply #6 on: January 13, 2008, 01:56:49 PM »
Don't loosen the head, just re-torque to factory specs and in sequence. I hope its not to late ,but  it sounds like it has already Blown out.  Does this engine have the "stretch" type head bolts ( bolts you torque up 1 Time and buy new ones when you have the head off for some reason) If you do have stretch bolts and try to re-torque ,you are taking a big chance that they might break off in the block. I don't know beans about Toyota, but I would find out before I got into big time trouble.
« Reply #7 on: January 15, 2008, 09:08:33 PM »
Bugtech,
 Would I like loosen each bolt  half turn then retorq it in the correct order.
Or just torqu it tighter from the position its in?
« Reply #8 on: January 16, 2008, 07:57:10 AM »
I think I would torque to specs. from where they are now.
« Reply #9 on: January 16, 2008, 01:41:43 PM »
What David said, SC
just check the torque where you stand.  If you go loosening up stuff, coolant or oil may slip into places where you don't want it.  I had a jetta a while back that would only loose coolant at night after being run at operating temp.  Found a small crack in the head that would barely seep coolant into the combustion chamber and, incidentally, caused a cold start misfire on that cylinder.  Held pressure fine, leak down test also OK.
Only indication of coolant loss was some discoloring on the plug.
Weird.
