The heat of August got to me. I was out working on Stupie Sunday. the bank Temp at 5:00 was 102. I tried to replace the dryer switch but found out the switch I got was an always on and went off when you flipped it. So that was a bust. then I took the switch apart cause I thought I could turn it into a always off , momentary on. But it broke and I started to get heat stroke. so I threw it in the general area of the garbage cans.
I had all the horn chrome removed and put that back on , But my hands got sweaty and I dropped all the springs and screws on the floor board. Since I did not have any carpet they all bounced around everywere so I had to take all the seats out to find them.
At Bugapalooza I got a emergency brake lever and put that on. Whoopee. I had been using a redwood block to hold the E-Brake on for the last 2 years. I'm gona miss that redwood. Maybe I'll whittle something out of it.
THe Dryer switch for the Starter has been about 20 feet of wire going from the battery to the dryer switch to the starter, no fuse just, SC engineering.
I tried to figure out how the wires go to the 8 buck ignition key I bought, but it is whack or I'm not smart enough. I did rewire the switch so it is under the dash and I think it is going through a fuse...maybe. Now when I get the good fortune of having a passenger they dont have to worry getting thier feet tangled up in the starter wires and burning tto death should an unexplained fire spontanously combust
Whew. What along Post.... Not done yet though...
Back to the E brake, SInce I put the new lever in, WHile I was driving to work . I can go about a half mile and never use the foot brakes. when I did reach the stop sign, AGGGGGHHHHH, no brakes.... Quick pump pump pump... then stop. That can really wake a dude up on a monday morning Evidently when you change the E-Brake lever , Maybe you should reset the little star wheels in the back brake shoes
Talked with Zen at Bilo Monday
Monday evening , under the car, trying to figure out which way to spin the spur gears and why there are so many mosquitos under Stupie.. Brakes a a bit better now. I can't wait to try them out today. SC
