Topic: Help with Slow Starter  (Read 231575 times)
« on: April 17, 2005, 05:59:17 PM »
Hi, I have this 70 bug and the starter turns the motor   too slowly.  My battery is good.  Even with a boost charger on the battery the motor spins slow.  I took the starter out and the 4 brushes are good and I greased up the front of the starter were it engages the gear out.   It worked great that day.  I was pleased .  The next day it was turning the motor too slow again.  any thoughts?   SC
« Reply #1 on: April 17, 2005, 10:35:38 PM »
More than likely, your starter bushing is worn out.  It's a little brass bushing that is pressed into the bell housing of the transaxle that the end of the starter rides in.  When it gets worn just a little, the starter will drag.
The bushing cost anywhere from 99 cents to two or three dollars depending on where you buy it.  If it's your first one, they aren't easy to change but after you've changed a few, you can do it blindfolded.
There is a special tool to remove the bushing and I've seen several different home-made tools that work.  But, for me, the easiest way is to thread a M12 tap into it.  When you thread it all the way, the tap will bottom on the engine case . . . keep turning and it will walk the bushing right out.
Try to find a deep well socked that tapers down at the hex end.  You want the diameter of the small end of the socket to be just a little smaller than the inside diameter of the bushing, and the big end to be a little bigger.  Stick the bushing on the socket with wheel bearing grease (you don't want to drop down in the bell housing).  Use a short extension on the socket if you have to . . . line the bushing up with the hole and tap it in.  Stop when it's flush with the flywheel side of the bell housing.  Put a little grease in the bushing and re-install the starter.  If the starter has not damaged its self from dragging, it should speed up to normal.
Offline Jason
  • Ringgold Ga
« Reply #2 on: April 18, 2005, 12:48:07 PM »
If it's a Auto zone or a advanced auto starter it could be bad.I've had trouble with three brand new ones. They start out fine at first and then about three minutes of trying to start a engine they start dragging and making some bad noise.You would be better off with a used german starter.
I think it says Bosch in the rust on the starter
« Reply #3 on: April 18, 2005, 07:07:18 PM »
All
I am getting good at replacing this starter.  I took it out,  opened it , greased the bearings and dumped out the black brush crud, re assembled. installed.   then it did not work.  I said to myself"  Self?  what is the relay thing on my bench for?"   Then I took the starter out again and put the relay thing back on .  As a said before it worked good for a day.     So I am pretty excited about taking it off again and replacing that front Bearing.  A new one at Advance or Auto zone is  is 40 bucks ( I get these stores confused),   and the bearing is 3 bucks.   I'll get the bearings  and try out your advice. Thanks for the advice Zen!
I see your super bus pass me every day.  I drive the toyota eqivalent , a Silver 85 van.  Big and slow like the bus.
Thanks also to Jason.  Your right.. this  here starter does screeeech.
SC
« Reply #4 on: April 18, 2005, 09:42:30 PM »
OK !!!!! ALL TOGETHER NOW !!!!    Bosch-Bosch- Bosch !!!!!!!!!!!!!!
  Zen, How many times have we said this ?  :roll:
  Auto-Zone :pukeright:
  Advance Auto Parts :pukeright:
« Reply #5 on: April 19, 2005, 07:06:17 PM »
Bosch is the only way to go!  Most of the time you are better off with a half worn out Bosch part than with a brand new non-Bosch part.  If it's electrical and Bosch makes it, DO NOT use anything else.
Got the starter off
« Reply #6 on: April 19, 2005, 07:31:13 PM »
Well I pulled the starter again.  its getting late so I'll take it apart Wed.  Thanks All
« Reply #7 on: April 19, 2005, 09:12:51 PM »
From CIP1.com's web site:
"We only sell genuine Bosch starters. Because they are the best - don't waste your time and money on a no name starter. Guaranteed for 12 month / 12-000 miles."
« Reply #8 on: April 19, 2005, 09:17:14 PM »
By the way Smelly Cat, where 'bouts in LaFayette do you live?  I'm in "downtown," right across from the Family Dollar.
Offline Jason
  • Ringgold Ga
« Reply #9 on: April 20, 2005, 07:30:56 AM »
I was also wondering were do you live? I live in Lafayette to. I reckan it's good to know theres other Vdubbers in Lafayette for those days were on the side of the road. Don't you thank Zen :lol:  :lol:  :lol:
« Reply #10 on: April 20, 2005, 05:30:30 PM »
Quote from: "Jason"
. . . I reckan it's good to know theres other Vdubbers in Lafayette for those days we're on the side of the road. Don't you thank Zen :lol:  :lol:  :lol:
Hummm . . . what makes you think I would know anything about being on the side of the road . . .  :lol:
« Reply #11 on: April 20, 2005, 05:35:56 PM »
Zen and Jason
I am back on west reed road north of town,  I looked at that old bus you sold a year or 2 ago parked at  the family dollar.  was it blue ?  Mike.
« Reply #12 on: April 20, 2005, 05:44:38 PM »
The Blue and White '66 Deluxe that was about half bondo?  That wasn't mine . . . it belonged to a kid that was living with us at the time.  He ended up selling it to a guy in FL for $4000.  Like P.T. Barnum said, "There's a sucker born every minute!"
Offline Jason
  • Ringgold Ga
« Reply #13 on: April 21, 2005, 08:13:12 AM »
Zen I only drive my VW when I can on the weekends. And I seem to forget when I last put gas in it. Or I seem to find all those bugs that I haven't worked out until I drive it.  :-k
i tried to tap out the bushing it aint cooperating
« Reply #14 on: April 21, 2005, 06:04:06 PM »
Zen,  I got a m12 tap and ran the thing in.
I have bottomed out and the bushing aint moving yet
I seem to be boring through the bell housing now.   Do you recomend I get a M13 tap and try that?   Should I spray some oil in there?
My arm is tired also
SC
Did you see me in the silver toyota van today when you got stuck at the light at the middle school?
