Topic: Heater Channel Rust - Anyone ever repaired a heater channel?  (Read 3802 times)
« on: February 11, 2004, 10:50:41 PM »
Sunny (Joy's 75 Convertible Bug) is about to undergo a major (but ultra low budget) amature restoration.
I'll be pulling the body off to deal with some rust and replace the driver's side pan.  I've already replace the passenger side with the body on.  There is some rust through on the top/inside of the passenger side heater channel beside the battery.  It's under the back seat, so I'm not worried about how the repair looks.  What really worries me about the heater channel is the internal heat pipe is rusting away from the inside out near the vent, and when I bolted the new floor pan, I broke off one bolt and two of the other bolts broke their welded-in nuts loose.  I would like to drill out the spot welds and remove the support rail and bottom plate from the heater channel, then remove the internal heat duct and get rid of ALL of the internal rust.  I'm afraid if I just patch the outside now, I'll be needing a heater channel replacement in two or three years.  Has anyone here every done anything like this?  I'm not a body man . . . I'm 110% open to any tips or advice!
While I have it apart, I'm thinking about trying to replace the heat duct with PVC or some other type of plastic pipe.  Plastic pipe would be less prone to sweating during the heating/cooling cycles this duct goes through wouldn't it?  I know it wouldn't rust, but if it sweats excessively the outer part of the heater channel would rust from the inside.
Offline Bugz
  • Burlington, NC
« Reply #1 on: February 13, 2004, 03:25:38 PM »
I went and took a look at the web site for those "Bug Me" videos you recommended for "Ken" who wanted to rebuild his bug engine himself and I saw that they had a volume on "Heater Channel Replacement." Might be some info on it that would help you (though I doubt they would say anything about using PVC). Glad you mentioned those videos though as I am going to have to replace my floorpans and the last time I attempted to take the body off to do that I had a lot of trouble and it never seemed right after that. I'm hoping those videos will give me some good info. :)
« Reply #2 on: February 15, 2004, 08:07:07 AM »
How about fiberglassing it?  I'm no body man, either, but that might help as long as you treat all the rust so it doesn't rust out under the patch (panel bus).  As far as sweating goes, I think that would be more of a problem for something with cool air passing through (a/c) than heat.  I mean, beer glasses sweat and coffee cups don't, right?
« Reply #3 on: February 15, 2004, 11:23:10 AM »
Quote from: "Anthony"
. . . beer glasses sweat and coffee cups don't, right?
That's true, but when the heater duct is cold and you throw hot moist air through it there is some initial sweating isn't there?  But then I guess the heat would dry it up pretty quick too.  I'd just like to make sure that once I fix it, I never have to worry about it again.  At any rate, I've got to repair or replace the heater duct . . . I guess that getting rid of the rust, treating everying inside and out with POR-15, then making the repair with fiberglass would be the best solution.  After I thought about it a while, I'm not sure how PVC would hold up to the heat anyway.
« Reply #4 on: February 15, 2004, 12:52:48 PM »
As for the fiber glass idea, until it gets a lot of age on it, fiber glass has a odor and I think heat would compound that. How long I don't know but something to think about. Surly you're not the first to think about using fiber glass in that area. Have you looked at any of the forums yet or put out that question?
        :cool:
