Topic: Bus height  (Read 3900 times)
Bus height
« on: January 22, 2014, 11:17:21 AM »
Need the height of a stock 70 bus,  non camper, need to see if it will fit in my garage
Re: Bus height
« Reply #1 on: January 22, 2014, 11:35:05 AM »
I have gotten the westy in my garage which is only 7' doors. I had to pull the door all the way up to clear the low hanging connector piece on the opener, but it fit. And that was with the westy top. It should fit easily inside the door.
I still need to get the ball joints from you! Don't use them on your new bus...
Re: Bus height
« Reply #2 on: January 22, 2014, 12:09:56 PM »
It's not mine,  someone traveling through chatt blew their motor
Re: Bus height
« Reply #3 on: January 22, 2014, 12:23:16 PM »
Here you go, from the 1970 owner's manual (taken from the samba):
Stock unladen height is 77 inches.
Re: Bus height
« Reply #4 on: January 22, 2014, 04:25:20 PM »
Thanks,  I'm gonna check when I get home in case the question comes up in the future
