Worthwhile points all around...
Currently the thought is that the 60lb compression on #1 cylinder is driving the high temps...
Yup. running the GEX, I got the vehicle knowing full well the implications of the poopy rebuild, but I'm still gonna try like heck to keep it running as long as I can... has 3K+ miles on it, with compression running 60, 90, 115, 115 and temps of about 350-450F and 13-15mpg on most days. I've toyed with the idea of renaming Neptune to Tick Tock, in deference to the GEX Time Bomb... when it dies I'll hopefully be able to use it as a core for a reputable rebuild.
Anywho, I decided to throw out the Bentley/ Haynes (not really), grabbed a Beer of Courage and reread the suggestions above, then do things in a more informative way for me, since spec isn't cutting it.
That said, here's what I did. Verified I was at #1TDC via the method described above (ayup), adjusted them all again to 2 turns past zero lash (which is really relative to how strong your fingers are and is difficult to quantify). Still no start/ fire, sounds like squeezing the life out of a meowing cat made of metal.
Adjusted lifters to 1.75 turns. Wanted to start, now sounds a bit like metal kitten caught in elevator doors.
Knowing all this, I decided to skip 1.5 turns (since it didn't seem to work), and try the other end of the spectrum, starting at 0.5 turn.
I set everything at zero lash, and ran it for 5 minutes to pump up the volume- er, lifters; beast fires right up, sounds good but very "clicky"...
Stopped, set #1 and #2 (at their respective TDCs) to 0.5 turn in. Ran it for 5 minutes again, set #3 and #4. Still clicky, but a bit quieter. Decide to jump ahead another 0.5 turn instead of 0.25 turn.
Stopped, set #1 and #2 (at their respective TDCs) to 1 turn in. Ran it for 5 minutes again, set #3 and #4. #4 definitely has a squishy exhaust lifter; bummer. Started it up, sounds fine, hear the lifters fill and mute then get terrible knocking noise. Stopped, popped off 3 and 4 cover, found #3 exhaust rocker loose even at TDC, so the rod must not have been seated correctly. Mucked around until I thought is was seated properly, set it to 1 turn in. Fired it up, sounds fine, idles great, set timing by ear/feel (until the new SVDA arrives). Drove it around for about 2 miles, feels solid and peppy (which means I've probably got the timing too advanced) and idles evenly.
So, any suggestions appreciated on whether I should adjust further... ?
I might try 1.25 turns and see if it quiets a bit more. I'm wondering if I have hydraulic lifters but rods for the solids... the rods look a bit thick to me but I don't know if hyd. rods VS solid rods were different in length as well as thickness... if so that might account for some of the wierdness. The rest (of the weirdness) I blame on GEX. Here's to hoping I see some improvement on #1 compression!
Thanks! mike
