ok guys..
i did move the spark cable from cylin.1 to clyn. 2 and mover all off them accordingly 1432....I set the timimng at TDC (when i did this wth the testing light the light never came on, actually as i was turning the dist. waiting for the light to come on i heard a click in the coil, but the testing light never came on, so i just adjusted it with the click from the coil....is that normal., the click??)
anyways......recheck cables, recheck "click", i loosened the idle screw (in carb, upper left side of gas reservoir), just enought to not be tide.
The car startes...not backfiring....idleing....I never heard such a sweet sound sound on this beetle since i got it
.......it only backfire twice on two different ocassions, but not as loud as it was before....I guess it needs to be on its proper timing.
1. what should i tell the mechanic where to the set the timing on? i know i need to know the rpm for ideling and the degree on the pulley for the setting, but in my case where things are out of normal place....where should the timing be set? can any mechanic with a strobe light be able to do the job?
1972 super beetle
2. now I started with the brakes...normally i have to push the pedal more than half way for the car to start stopping..and then i have to push very hard for the car to come to a complete stop...this doesn't seem right to me. the adjusters in the back of the drum should fix this problem? the mechanic install a new master cylinder, flood the brakes, but he did not know where half of the brakes went. (whom by the way i will not trust my bug again
Thanks guys...u really made my saturday, even my wife was happy that the "thing" was sounding good.
